rodman99999
- Mar 25, 2004
Brand new in the box:  I have four DM-100 Intelligent Multi Function Displays and two SM-AFR wideband O2 sensor kits to sell.  The gauges are 52mm, and expandable with a variety of sensors.  You can monitor virtually every engine parameter through this one display by daisy-chaining sensor modules(pictured on the "module" site below).  (PLX Devices Inc. - Multi Gauges, Single Gauges, Sensor Modules, Wideband Air Fuel Ratio, Data Logging, Fuel Saving / Scan Tools) View the video, BTW.    PLX SM-AFR info: (PLX Devices Inc. - Sensor Modules, Wideband Air Fuel Ratio, Air Intake Temperature, Exhaust Gas Temperature, Vacuum/Boost, Oil Pressure, Fluid Temperature)  The SM-AFR is complete with the Bosch wideband sensor as shown.  Pics available.  DM-100= $165.00, the SM-AFR= $155.00  both plus shipping via UPS, tracked and insured.
			 BTW: The DM-100(2 1/16") will fit any of the gauge holders that we use in our TRs, and with it's multi-functions, will replace whatever other gauges you might choose.
