I am thinking of getting the PLX M-300TE but looking over the online instructions they seem a little confusing.They say to locate the 2.1mm power cord and unscrew the plastic cover and insert it into the red/black power wires,solder or crimp the red wire to the center of the connector and solder or crimp the black wire to the shield of the connector.I would of thought that the connector would of been assembled at the factory and that there would be pig tails for the power and ground,am I reading this right or am I just misunderstanding it ? I also see the unit has 4 terminals for analog outputs (3.3v power,ground,narrowband,and wideband), when you wire the unit to a PowerLogger do you just use the wideband analog terminal and wire it to port 1 on the PowerLogger analog box ? What do you do with the other remaining analog terminals ? Also when you wired everything up did you have to drill any holes in the firewall to connect the wideband O2 sensor to the unit ? Thanks any info would be greatly appreciated,ikle.
