Mar 25, 2017 #1 T tford Registered Member Joined Nov 17, 2004 Messages 599 I am having a problem splitting the circuit boards apart. What am I missing. Took screws out and they are still stuck together
Mar 25, 2017 #2 T tford Registered Member Joined Nov 17, 2004 Messages 599 Ok Got it. Now for cleaning the circuit board. Does all of the glue/gunk need to come off so just the prongs are exposed?
Mar 25, 2017 #3 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 You may have to pry on them a little. The boards have a conformal coating on them for weather protection and they are probably "glued" to the metal bracket.
Mar 25, 2017 #4 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 tford said: Ok Got it. Now for cleaning the circuit board. Does all of the glue/gunk need to come off so just the prongs are exposed? Click to expand... Just where the Powerlogger plugs onto the board....both sides.
Mar 26, 2017 #5 T tford Registered Member Joined Nov 17, 2004 Messages 599 Ok. I got it. I realized the glue was just a thin coating. What are symptoms if glue is not cleaned off enough?
Mar 26, 2017 #6 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 tford said: Ok. I got it. I realized the glue was just a thin coating. What are symptoms if glue is not cleaned off enough? Click to expand... Could be anything....communication problems, corrupt data. I use lacquer thinner to remove the coating.
Mar 26, 2017 #7 T tford Registered Member Joined Nov 17, 2004 Messages 599 I was going to use finger nail polish remover but was afraid it would screw something up. I guess we'll find out soon enough.
Mar 26, 2017 #8 B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Messages 3,548 tford said: I was going to use finger nail polish remover but was afraid it would screw something up. I guess we'll find out soon enough. Click to expand... Use Goof Off
Mar 26, 2017 #9 Turbo6inKY Short Guy TurboBuick.Com Supporter! Joined Jun 18, 2001 Messages 2,146 tford said: I was going to use finger nail polish remover but was afraid it would screw something up. I guess we'll find out soon enough. Click to expand... Finger nail polish is acetone. Not the same as lacquer thinner. Use lacquer thinner, and only use it on the edge connector.
