Poerlogger question
tford
Registered Member
I am having a problem splitting the circuit boards apart. What am I missing. Took screws out and they are still stuck together
Ok Got it. Now for cleaning the circuit board. Does all of the glue/gunk need to come off so just the prongs are exposed?
You may have to pry on them a little. The boards have a conformal coating on them for weather protection and they are probably "glued" to the metal bracket.
Ok. I got it. I realized the glue was just a thin coating. What are symptoms if glue is not cleaned off enough?
Could be anything....communication problems, corrupt data. I use lacquer thinner to remove the coating.
I was going to use finger nail polish remover but was afraid it would screw something up. I guess we'll find out soon enough.
Finger nail polish is acetone. Not the same as lacquer thinner.
Use lacquer thinner, and only use it on the edge connector.
