I did both, my mistake. Chased what felt like wheel balance/front-end trouble for quite a while before I figured out what it was. The engine at 2200 rpm cruise, makes a harmonic that was amplified and felt through the steering wheel. Switched out the passenger side and it all but went away. If HR makes another one that is even softer I would switch the driver's side for the 3rd time. The first was waaay to hard, second design is better but could be a little softer. I will also add that putting poly body bushings is a mistake for a street car, stay with factory. With the driver side my engine doesn't move at all.
Mike
