Guys, I'm having trouble with my HrpartsNstuff Poly motor mounts lineing up on my TTA. The passenger side bolted up with no problem, but I can't see any way that the drivers side mount will bolt up to the supplied pedestal. Am I missing something here? Car has the original motor and I removed the original mounts to put in the Hrparts mounts.
Howdy Gewehr455!
Yep! Had the same problem myself. Have a buddy help you out. Get a long pry bar (rent one if you have to) loosen the 5 bolts that you have installed. Get a good pry angle (just don't use the oil pan) and force the motor over, then use the stock motor mount bolt and knock it thru. The stock bolts are pointed the HR bolts are flat nosed. The pointed bolt will go through. You need the freedom of moition.
