wbzautocustomiz
Want my GN to go 11's one day
- Feb 11, 2007
Scanmaster tps wont get past 2.5 before breakup starts, bl's are 134 at idle wot 119 what does this mean for the bl's on scanmaster?
SignUp Now!As you are finding out these cars can be very frustrating indeed. You stated that you set the Cam and Crank Sensors. My strong recommendation is that you replace the crank sensor. I have had similar problems and through the process of elimination found the problem to be the crank sensor. Car would start normally but at some early point in time it would begin to buck and pop. Crank sensors are available at most parts stores for about $45.00. Don't know how to test them but have 2 that failed.
Yes new crank sensor and bracket set with feeler gauge and 2 liter plastic material, new cam sensor set with casper cam tool and identical problem before and after with old and new. The flickering CE light I do believie has the answer to my trouble and fyi with all 3 tt chips I have they all cycle thru tt's procedure key on few quick flashes etc so chips seem ok I have 3 ecms also all do the same, but what's missing when I unplug cam sensor while running and car shuts off not good right? Is there something missing between ecm and cam sensor? Just fishing I'm hoping can find problem. Thanks
