Well the spring in the wastegate was too stiff(15lb). I ran the vacuum line straight from the turbo port to the side port on the wastegate and now it holds boost right around 14,15psi. I ordered a new 8lb spring and hopefully that will fix the problem.
Thanks for everyones help
