My car has been popping at bost levels above 17 psi. It's worse above 20. I've been chasing this problem for a few months. Did all the ignition related things. Today I went to adjust the boost up to test. No matter what I did,I couldn't make more than 20 lbs. I then pulled the hose to the wastegate actuator and plugged it. When I took the car for a drive,I put the pedal to the floor and only made 20lbs. of boost. There are no exhaust leaks before the turbo.
