Port for hooking up an Accusump??
TR Custom Parts
Mark Hueffman - Owner
Let's say you aren't using the port normally used for feeding oil to the turbo. Would that be a good place to hook up an Accusump line? Got an Accusump just hanging around doing nothing. Had it installed before at the front of the car in front of the radiator but when I went to a front mount I lost that space so yanked the Accusump out of the car.
With that setup I tapped into the return line from the oil cooler with a check valve and tee. By tapping into the former oil feed port I can eliminate the check valve. Going to be feeding the turbo from a different source soon sort of like the Turbo Saver does.
Probably going to mount the Accusump somewhere in the trunk.
