These head were done by Jack Merkel Performace in Clark NJ
stainless valves 1.51 ex 1.77 int, bowl blend bronz guides
factory exhaust guide was cut down to make room for viton seals(see pic)
If not you will get some smoke on start up.
comp cam spings 120lb seat psi when new most springs will lose about 10lbs
of seat psi after first run. you can use flat tappet cam or roller I was using
comp cams 212/212 504 lift with 1.55 rocker, 520 lift with 1.60 roller rocker
the rocker mount has been shaved so you can put roller rockers with out modifing the rockers. these heads were on my car for 2000 miles. my car
has gone consistantly in the 10s with these heads my best pass 10.66@130.87, 24 psi. have video of 10.78@127 22psi LT GTQ 70 turbo
If you dont pick up .5 tents with these heads I will buy them back.
I paid $1200
I would like to get $850
thanks steve
610-972-5462
I paid $1200
thanks steve
610-972-5462
