- Aug 24, 2012
For those that have turbos with ported shrouds, did the shroud get rid of part throttle surge? I have a TE-44 and PTE SLIC and I'm tired of the part throttle surge.
SignUp Now!That's exactly what I wanted to hear. Thanks.I'm running a .63 A/R Precision DBB 5857 Billet Wheel Turbo with S ported Shroud, Precision SLIC and am happy report that there is no surge here at all!
That's weird. I went from a ta49 stock cover to a 6262 ported anitsurge and there was no comparison. The ta49 had a nasty surge. My s366 current turbo will surge a little also with the ported housing. Does your 6266 have the holes in the turbo inlet?I have a ported shroud S cover gen 2 6266 and it definitely still surges at part throttle so I try not to be there. It definitely got worse when I installed the rjc FMIC which has more volume than the stock one
Sent from my VS990 using Tapatalk
Yes. I dont think it did it much with the stock intercooler but it does it badly with the RJC 315 FMICThat's weird. I went from a ta49 stock cover to a 6262 ported anitsurge and there was no comparison. The ta49 had a nasty surge. My s366 current turbo will surge a little also with the ported housing. Does your 6266 have the holes in the turbo inlet?
Yea idk. Its only at around 1/2 throttle 10-15 psi and it will surge to the point it will sputter ans if you let out it will sputter more etc. No problem at WOT 27-30 psi though. 17 blade ptc converter. Idk if that changes the loading enough at part throttle to matter
Could. Mine are a ATI 3200, PTC 18 blade, single disc vigilante and a ptc 19 blade.
