SignUp Now!It's the same Scott. Just make sure to measure it.
say what?
its wider than a GN by 1" or so
carrier is the center section, the axles are longer because the car is wider but check with Moser to be sure I had a 77 regal and pretty sure I am rightplus older camaro and firebirds had 8.5 gears in the 70's you can use it but your wheels should stick out more. Just measure your 7.5 from the backing plates and the one out of the Monte carlo. plus the rear drums might be bigger to since it was a heavier car.
