Thanks for helping me figure out which direction I need to go. With the current setup @ 0 boost the engine is at 2500 RPM. The 6152 has propelled the 3650# car to 10.73 @ 125 at 22-23# of boost. I ran into an issue the last few times at the track unable to get the boost turned up higher than 23#.
I may switch converters sometime in the future, however would like to try and run the Vigilante if able, I know that it's not as efficient as others. I don't think that I would like to go with a higher stall as I do drive it on the street to area events.
I am going to stay with the 3 bolt headers. The fuel system is going to be reworked as well, 80# injectors and still undecided on the pump, waiting to see how the newer intank pumps perform or go with a double pumper. I would like for the car to be capable of high 9's when finished.
Bison, have you done any testing of the billet 6765 series turbos? Can you suggest whether I should go journal or ball bearing?
