Well I was pretty set on going the LT1 V8 route...but I kept feeling like I was betraying my cars marriage to the V6 or something??? Don't know but I just did which is odd for me...
But anyways I was thinking of doing a 4.1 swap....I been reading the recipe for it but the whole being a PIA to switch to some type of EFI killed that idea.
That was until I seen this....
Professional Products Online
Now I remember I believe it was Warhawk that said the EZ EFI system would not work with the T/C because it was only "single bar" or something like...This system does ...it has 2.5 bars and it says it can handle being Turbo Charged or Super Charged....It's also a few hundred dollars cheaper
Now...I ask the resident brainiacs here...Could this system be used with our motors with all the goodies and a 4.1? According to the recipe it says everything will bolt up no problem...just gotta the normal EFI conversion thing like changing the Gas Tank, adding the oil return line to the block.
Just throwing some ideas out there....My Caprice money and my Income tax dollars are DYING to know!! Because if this can work out im not going V8!!:biggrin:
I mean this opens the us up to bigger turbos (Well not too big I think this kit only supports up to like 20lbs of boost and 600 hp? )Or we could use the stock turbo from the 86/87? A bigger down pipe (Or stick with that custom one for our cars you guys talked about a while back ) Would this setup be able to be intercooled? Stroked 4.1 or the 3.8?
