TOOMANYTOYS
- Oct 18, 2003
Been chasing a lean condition that shows with audible detonation. Thought I had it nailed with a broken injector. No such luck. While looking at my fuel pressure gauge I noticed it was at 23psi with the vac line on so I popped it off and raised it to 43psi line off. Took the car out for a drive and the detonation is worse. Disgusted I parked the car for the night. This morning I started the car and the fuel pressure is now 43psi with the vac line on. I let the car idle for a while and the pressure slowly dropped down to 35psi line on. Seems like the pump starts out strong but then starts to slip after about 10 minutes. The car is hot wired but the pump is unknown. Voltage is between 12.9 and 13.1. Previous owner told me he had a Cottons "stage one " fuel system installed. I've no idea what that is. The only thing I can verify is there is a Hotwire and there are 60# injectors in it.
Sound like a fuel pump or should I be looking elsewhere? If I do need a pump do I still go with the walbro 255 or is there better now?
