85begalttype
just a v6
- Oct 22, 2008
85 hotair motor, getting the motor rebuilt from a wiped cam lobe and very low oil pressure. Last year when i tore the motor apart, i was researching and decided to use the felpro1000 gaskets with a compressed thickness of 0.039 in. I brought my heads to the machine shop to get shaved down 0.010. As i read from someone on the board that the stock gaskets are a bit thinner, and that the heads will need to be shaved to match the compression ratio.
Now i read that the STOCK head gaskets compressed thickness is .063". So maybe im thinking i messed up and should have just got the 9441pt gaskets.
Now i am coming closer to the day when i bring my block in to get the bottom end rebuilt, am i fine with the 1000 gaskets and 0.01 shaved off? i made myself all confused and hoping i didnt make a mistake bringing my heads in...
