Dan SS2471
- Dec 12, 2008
That's an observation that embarrasses me despite whether or not it could be a factor and or actual root cause. It is a 6766 and was when I placed the order. I believe the previous owner worked with Bison on spec / purchase. I just searched to verify and found that you and others responded to some questions he had after installing. Chris996 - screenname. Where I got 6762 from.....I have no fn idea.Turbos have passed me by, but you have it burned for a 6762...and it appears you're running a 6766 now...which I assume is larger than the 6762...so you'll require more fuel in the chip with the presumably larger turbo that flows more air...and requires more fuel.
Thanks....
