Jan 1, 2012 #1 9 9SECVSIX Member Joined May 25, 2001 Messages 520 I tossed their catalog in the trash when they went under a couple years ago. Does anyone still have one that can give me the specks on the flat tappet 107 and who they used to grind them. Any mention who's lifters they sold. Thanks B.
Jan 1, 2012 #2 S SS502 Out with the good, In with the Bad! Joined Feb 2, 2011 Messages 379 Found this, may help a little. http://home.comcast.net/~shinzan/CamshaftGuide.htm
Jan 1, 2012 #3 S SS502 Out with the good, In with the Bad! Joined Feb 2, 2011 Messages 379 Cam card 110 Pic of a 110 card, but they are long gone as far as I know... but you can see old Phone number and address.
Jan 2, 2012 #4 M MikeL. Stay boosted my friends Joined Jan 24, 2006 Messages 525 Duration at .050 is 202/202 intake/exhaust, valve lift is .430/.430, power range idle to 5,600 rpm. Works with stock converter. Hope that helps.
Jan 2, 2012 #5 9 9SECVSIX Member Joined May 25, 2001 Messages 520 FatGnat said: Duration at .050 is 202/202 intake/exhaust, valve lift is .430/.430, power range idle to 5,600 rpm. Works with stock converter. Hope that helps. Click to expand... Thanks! To all that replied. B.
