Power Antenna, Alternatives and Options in 2023
GNVYUS 1
Well my fender is off due to installing the Caspers engine harness, I have a freyed radio to antenna wire, I believe this is called the..
Self-Reject Connector
Image below
Mechanic says new radios have a different connector and that there's a possible antenna swap out vs trying to find this connector.
Are there newer, from a different car, antenna motors and complete units that fit us?
Is the Mike Monte cable update the best option? In case I just roll with the factory unit.
Anyone know where to find that self-reject connector, wire?
I would look on casperselectronics.com for a matching pigtail. Most likely they have it. Do you have a photo of the actual connector since you have access?
Here's the radio to antenna wire that's frayed.
Steel mast....
Kirban only accepts Amazon Pay now.....
Monte does the rebuild but I don't have time to do all that....
Who else sells the steel antenna mast?
Go to best buy they have all of the antenna adapters there in the shop on the wall
And antenna cables in different lengths
Best Buy and Amazon have Metra products as do most install shops that have a showroom display area.
