Power antenna issues
gnx017
Greetings;
Has anyone had problems with the power antenna? The antenna is getting stuck 3/4 of the way down, at that point the motor keeps running. I have lubricated lightly, no effect.:(
Thanks,
sounds like the internal nylon cable is broken.make sure the masts are clean and not bent any.
I think its the most common problem with these cars :rolleyes: prob from sitting to much :p
Thanks,
someone had mentioned that in order to replace the motor, the fender has to be removed?
I cannot believe the great minds of GM in the 80's could have engineered a fix that simple!
