John Larkin
Sublime Master of Turbology
- May 25, 2001
I think I've been chasing my tail. When I powerbrake to build boost on the converter, I lose vacuum in the brake booster almost instantly. I can let off and brake booster quickly returns to normal. I have tested the check valve in the booster and it holds rock solid 25 in/hg on a Mity-Vac, no decay. What are the chances that my booster has a leaky diaphragm and can it be tested? When I pulled the check valve out after the car sat for a week, there was no burst of air pressure. I should retest it after running but this all just ran through my head while I'm here at work. Any thoughts?
I also have a very low pedal. It seems fine but just having so much travel in it before engaging the brakes is a little concerning. Maybe this is all related: low pedal, can't hold vacuum. Hmmmm....
