I just finished installing my power logger on a stock car. I followed the instructions from the vortex website but i seem to be getting low boost readings. I can't get it to read anymore than 10psi when i get on it.
I've set the option to 3bar map in the power logger. Also checked the grey wire and its reading 5.11v. It was reading 5.33v until i hooked it up to the ECM. I haven't done anything with the ground so i'm not sure if thats the issue or not. I've used a multimeter to check for a good ground at the sensor and its seems to be ok. Car is seeing some knock occasionaly 2-3 degrees when at 10psi of boost.
A little lost on what to try next. Could i possibly only be getting 10psi boost on a stock car?
