bobby690_11
- May 26, 2009
Hello again its been a long winter.I got the GN out two weeks ago and was out touring around and the brake light came on for no known reason I wasnt even on the brake.Looked at the 30 amp fuse and its shot .Put in another and Im good to go.Prior to this fuse it was doing it last year and was told it was the accumilater ball so I changed that same thing poped fuses.Got checking the fluid and it looked a little milky,got that changed,no cure.Called a brake power master guy near me and he said there would be nothing wrong with the power master but to check the wireing that runs from the master to the battery.He says that it runs down under the rad and sometimes gets rubbing and will cause it to short out.Anybody had this problem or could it be the power master?
