Power Plate...my opinions
GNSteve
EFI Unlimited #4
I just recently installed the RJC Powerplate on my GN. (The real one, not the fake) BTW, you can tell the *real* one from the small "RJC" engraved into the plate.
Anyway, just in case any of you were looking into getting one of these, I'll share my experiences with mine.
Installation was a snap. Under half and hour by myself, including "clean up" time. Took off 5 bolts, undid the connection from the IC to the uppipe, disconnected the linkage/vacuum hoses, lifted manifold up. Removed old gasket and cleaned surfaces. (not too dirty on mine). Installed 2 gaskets with the plate. Prior to this, I drilled a 3/8" hole as per the instructions so my EGR would work. Re-installed everything.
The ONLY problem I had is that the bolt in the very back by the coil seemed too short to me. I guess this is where people ran into the issue with stripped manifold threads in the past. The 4 bolts along each side of the manifold sealed well. I replaced all bolts with Locktite Blue and hoped for the best. I could get some torque on the back bolt, but not as much when compared to the ones on the sides.
Fired her up, no immediate signs of any problems.
So, what's the verdict? Well, after driving to and from work today, I've experienced NO drivability problems. The plate *seems* to have cured the "off-idle" stumble I had when I "blipped" the throttle real fast at idle. Doesn't stumble anymore, no matter how fast I press the pedal. Cool.
On the way home, I opened her up a little on H2. I hit 22 psi, O2's were in the low 800's, NO transitional knock. Tried another run to duplicate the results, and again, no knock.
What else can I say? The plate works. Got rid of my transitional knock, my "off-idle" stumble, and seems to have improved my throttle response. For $60, you can't go wrong.
Sorry to make this so long. I hope this helps someone who was thinking about buying a Powerplate. Any ?'s, feel free to ask.
Steve
Steve,
Thanks for the info. Maybe I need to look into the power plate and see if it will work with a Hemco.
sorry, I used to have the race Hemco. The plate doesn't work with it. The race hemco is supposed to take care of the same problems as the plate, so it shouldn't be needed.
Derrick
Hey Derrick,
Thanks for the info. Hopefully the Hemco will be as good or better than the Power Plate. Do you know if there were any comparisons made in the past?
Derrick/Gay,
I don't know anything about the Hemco plenums, but for $60 the Powerplate is hard to beat. Unless, of course, you got a Hemco for *free* or something.
I know they make plates for other plenums, why not the Hemco, I don't know.
BTW, any of you guys planning to show up this Friday @ Anna Millers?
Steve
Lots of data available via "search"
Go to "search" feature, above/red/right, type in:
power AND plate <----- just like that
and all the above questions are answered in great
detail in previous threads. You may be surprised!
Great to hear another positive first-hand account!
Beaten to the punch. :) But yeah, Jason at RJC only designed the plate to work with the stock plenum and the accufab plenums. The hemco RACE plenum is a radical design that supposedly solves the lean cylinder conditions in it's own way. True, there now is now reason to get the hemco race plenum for ~$250 when the plate is out there. But in my case, I had the plenum before the plate was available. :( But it was on RJC's website as well.
Derrick
Oh, I won't be there Friday at Anna millers due to other commitments, but I WILL (assuming no rain out) be at the cruise at Wendy's Saturday.
