in looking at the power plate i think it will be the answer to my knock problem....but my plenum now has a spacer i don't know if it is stock or not but the vacuum blocl is rubbing on the hood pad if i add another 1/8 of an inch it will be putting a hole in my pad.... is this spacer stock ???? should i remove it to install the power plate any help would be appreciated thanks
