power plates??
drive805
in looking at the power plate i think it will be the answer to my knock problem....but my plenum now has a spacer i don't know if it is stock or not but the vacuum blocl is rubbing on the hood pad if i add another 1/8 of an inch it will be putting a hole in my pad.... is this spacer stock ???? should i remove it to install the power plate any help would be appreciated thanks
No, the spacer is not stock. I believe it is recomended not to run a spacer with the power plate. Get the power plate, you'll be glad you did. I was able to run about 2 more psi of boost with no knock:D
I was told to take my plenum spacer (1/2" phenolic) out for the power plate install.
Didn't help my knock problem however.
more boost
i started it wrong....what i mean is that i can run more boost then 12# with little or no knock.....power plate looks like the way to go....
walboro 340 fuel pump
hot wire kit
bluetop injectors
k&n air filter
fuel filter
thrasher 92
POWER PLATE
16 psi and it shouldnt knock unless you have other problems
NEXT
smc alky kit
good flowing exhaust
bleeder valve
23 psi and no knock
HTH
I went from 1/2" spacer to power plate with no help in the knock department either...
