- May 28, 2001
Do you recall the part # for the fitting? I have the same MC. It must be OK to have the fitting installed at the bottom of the reservoir? I was thinking of placing the fitting above the fluid level in the reservoir
Do not install above the fluid level. That will aereate the fluid.
I used a Fragola #6 AN Bulkhead fitting w/ the long end cut off. I then used 2 nuts, and 2 nylon washers to seal the fitting. The washers are also from Fragola.
I also use a cleanable filter in the return line from both the HB, and the steer gear. They fit inline on a -6, or 3/8" line.
