Anyone happen to know a part # for a power steering pump pulley for 86 G.N. that's "steel" flat/smooth surface that the backside ( not ribs) of the serpentine belt rides on?
I had to replace the R.J.C. aircraft light weight aluminum idler pulley because it fell apart, the pulley itself turned into a chinese throwing star that the drive belt was riding on.
I can see the power steering pump pulley is also compromised and I want to preemptively change that pulley to a steel one.
The car originally came with a "V" belt pulley so that's no longer viable.
If you search youtube, there's 2 videos, ( one is the install & the other is removal) and the guy is using a smooth steel pulley but he makes no mention as to the pulley itself, just on how to pull/press it on the pump shaft.
Last thing I want to do is put another R.J.C. aluminum "RAZOR" style light weight pulley on.
Any help or input would be appreciated from anyone.
