Power to PM motor
Alaskabuick
Doing my yearly Power master rodeo! Seems like one of my cars always is in need of something related to PM. Looking on the bright side, I seem to learn a little more every time I have a new problem.
Well this time it is the motor. Put a new motor on and it will not run with key on to pressure up.
I only have power at Terminal "C" on the motor connector.
No power at all to any of the pins on the Pressure switch.
Fuse is good
From what I understand I should have power at Terminal B as well with ignition on.
Thanks in advance for any clues to solve the mystery.
Dennis
The pressure switch is a grounding switch so don't look for power readings there.
Pin B is the +12 volt source from the RLYS fuse 5 amp. which is active with the iginition key in the RUN position.
Pin D will be grounded when the brake switch is under 400 psi. or so.
Thanks,
Yes the RLY fuse was blown.
Replaced and B pin now has power however still PM motor still does not power up.
After about a min with key on the PM motor starts to give off little puffs of smoke and is hot.
I must have a bad motor? This is same symptoms as the motor that went bad. Is there a way to test motor?
Thanks for all the help, if anything i have learned what to look for.
Den
