Everything is making contact on the passender side.
All the terminals are clean.
The window goes up and down fine when using the drivers side switch, so I would think that the wires are sending signals over there.
I tried switching out with another known good switch today with no difference.
With a test light and the ignition on, all wires once plugged into the switch are hot. Is this correct? when the wires are not in the switch all but 2 of them are hot.
Thanks for the ideas, keep them coming please.
Matthew
