J-B Racing
Forced Induction
- Sep 16, 2003
So now that I got my 400 questions answered. Anyone here running a Strip Powerglide Transmission?
many of the cars up here have them what would you like to know?So now that I got my 400 questions answered. Anyone here running a Strip Powerglide Transmission?
they didnt break as often.if your combo needs the torque of the 400 1st gear that is why you would slow down.engine power,weight of the car and rear gearing/tire should be looked at.in the faster cars they pull the gearing down inside the trans and also adjust rearend gearing.did cars go faster or slower?
not that your wrong but my friends buick runs a glide and is 3700 lbs, tire and gearing and power are major factorsMy suggestion on the Glide stuff is don't do it unless your car is 3000 pounds or less this is been proven on a lot of drag cars
yes he has some powerbut it really is about the overall combo.i def wouldnt put a glide in a heavy car with no rear gear and no power that would kill it for sure.but the right combo it will go good and lastOh I'm definitely not saying it won't work just from what I've seen over the years it's better to have three years and pull timing your Boost out and play with that instead of spending a lot of money on a tranny in and out working like you hoped but I will say this I bet your friend's car makes a whole boatload of power and that is a little different ballgame
that sounds fun'm getting ready to build a super short stroke Big Bore engine on twins to see how that works out in my car and itweighs 3000 pounds without me in it so I'm all about being outside the envelope so to speak
dont forget about the converterYeah I agree with you on that and hopefully it will be going to be a 3.060 stroke I'm not sure how well it will work but I think like you're talkin about with the right gearing could be a beast probably going to have to Zing it to the moon but that's okay
I listened to this(I know it is to watch) and kinda think a powerglide with a gear vendors overdrive would work good with a new iron block Kenny Betts block( http://www.v8buick.com/index.php?th...st-iron-block-from-kenny-betts-racing.338429/ ) with a turbo. You know fer Drag Week or that rocky Mountain drag week.
