PowerLogger Basics...
03FatBoy
I purchased a PowerLogger about a year ago, but for a number of reasons, have not had the time to install. Now that I have a garage and some time, I am slowly working the install.
I have a basically stock setup, (see sig) and would like to know if I can install without a wideband and EGT... they can come later hopefully.
As far as the MAP sensor, do I just tap into (parallel) the MAP wiring?
... still learning!
Thanks!
Should be the same wire that you run for your Alky...I tapped into the stock "green" wire for my MAP.
