powerlogger I/O card ?
Go to Full Throttle's forum and download the manual on the Powerlogger. Show you everything.
Mount it anywhere you like(that the cable will reach to).. I have mine behind the dash, on the heater box, I think.. As far as activating it, unless you have something(like MAP, Wideband, EGT, etc) connected to it, there's nothing to activate, it wont do anything
map sensor
you need to launch plc and see which input (dont remember offhand) will let you select the map sensor then connect the green wire to that. you will want to goto fullthrottletech.com and make sure you have the latest version of plc (i think 2.2). It will need to be set to the correct type of map you have 2bar (stock), 3bar or 5bar. fullthrottletech.com has all the info you need, just search for it.
