Lee Thompson
- May 24, 2001
I'm sure I could find it if I searched long enough. I'm in the process of changing out a whole unit. I have the 2 nuts off but it appears that the rod is still attached to the pedal. Do I dis connect under dash or will the rod pop out of the back of the unit. The used unit I have has the rod with it but it is out of the unit. Thanks for your help.
