turbonut85
Rarely used member
- Apr 11, 2008
So I completely rebuilt my PM unit. installed a NOS GM rebuild kit with all new cups, O rings, power piston, and check valve/poppet. The entire brake system on my GN is brand new. Lines, brass valve, rebuilt calipers, new rear wheel cylinders. So I am TRYING to bleed the entire system. The PM side is not the problem right now. I am getting HUGE amounts of ari in the rear system and the pedal goes to the floor every time. The question is did I not bench bleed the master cyl enough? Would it be continuously pumping air into the rear lines? What about the proportioning valve? Do I need to do anything specific with it? I realize with the whole system being new I am going to have ALOT of air to get out. I had no problem bleeding the front system, or the PM side...aside from my acc ball being craptacular! ANY IMPUT would help IMMENSLY!!
