SignUp Now!No, not driving the car. Drove it home as soon as the BAD symptoms began. I have an acc ball on order, but am wondering if I should just bite the bullet and get a reman PM unit. Will turn out to be more expensive if I have to replace components one by one.
...went to look at the unit and found that the fluid is coming out of the body of the switch. Not around the threads, but from the actual switch. It was bubbling out at the base of the switch.
Interesting theory but not applicable in this case. The OP is not saying anything about blowing fuses. Which would be happening if the motor was shorting out.Another Possibilty Is The Seal Between The Pump And The 12v Windings Is Leaking Into The Motor, Shorting It Out. This Is Very Common.
