Few more parts I found in my closet:
Genuine oem Stock timing cover. 89k miles. Original oil pump gears and filter housing together. Also includes a new melting oil pump gear set stock volume,Fel pro water pump, oil pump, fuel pump blockoff gaskets. And I’ll throw in a high volume adapter plate and shims in the event you decide to purchase high volume oil pump gears. Does not come with any high volume oil gears.
Has one stud that you will need to remove.
Came off a running car. Minor cam button Wear.
$80 obo plus shipping
Complete analog gauge cluster. Works but isn’t mint looking. Comes with a brand new zero miles Casper’s rear wire ribbon with alternator resistor soldered into the ribbon so you don’t have to worry about the volt light.  Comes with 2 tachometer/boost lights. Both need to be recalibrated
I believe the mileage is at 59k
$100 plus shipping
(I paid more for the ribbon wire then what I’m asking for everything)
Stock air filter housing set. Comes with mount, bolts, inlet vent, outlet soft hose from maf to turbo. Does not include the maf sensor or air temperature sensor. The air filter element was thrown away. Will come with a fresh coat of paint if you want.
$65 plus shipping
