ITSAV6
It's my Granny's car!
- Nov 13, 2001
Does anyone still carry these and who?
SignUp Now!ITSAV6 said:Does anyone still carry these and who?
zeus87gn said:Sent you an email.
Local GM dealer wants over $200.
Kirbans doesn't sell them right now.
I hope someone will start making them reasonable in $$.
zeus87gn said:The link mikec1969 provided was to a place called Karps brake. They called me back. They have the switches and accumulators, original GM. the prices are as follows (better sit down):
Pressure switches - $300
Accumulators - $400
PowerMaster rebuild kits - $75, contains all new seals and cups (rubber components) for the cylinder itself.
I think I might get a kit, but Kirbans has the deal on the Accumulators. Doug, email me.
POWERBRAKEBOB said:The problem with those switches is that they need 2600psi against them to shut off the motor. It's a lot. It's also hard on the accumulator. The pump has phenolic (plastic) vanes, which wear rapidly pumping brake fluid under high pressure. With the prices up so high for components, the Hydroboost conversion gets cheaper. It also does away with the electric part of the system.
If you read the description, the switches offered on ebay can be used on the ABS offered on some GM cars in the late '80s. The ABS used the higher pressure. So if the switches are the ABS switches, then 2600 psi is correct.2600PSI? I raise the BS flag there bud
Ormand said:If you read the description, the switches offered on ebay can be used on the ABS offered on some GM cars in the late '80s. The ABS used the higher pressure. So if the switches are the ABS switches, then 2600 psi is correct.
That may have been what you meant, but that's not what you typed. You "called BS", when PowerBrakeBob said that the switches were not correct, that they have the wrong pressure setting. I understand what the pressure is for the PM, but I also know that the ABS uses a different switch. And it is NOT a later model switch, the ABS was available at the same time as the PM, just in different vehicles. PowerBrakeBob probably know that too. And now you have had the chance to learn something new.As I stated before,600-650 psi id where our sw cuts off the pump.
