OK... On the top side of the switch, along side of the connector is a very tiny black rubber "plug" that seals off a very small hole. What is the reason for it and the small hole? And if it leaks what is the solution? A pin-sized amount of RTV, nothing (let it leak), or replace the switch?
I've looked at a minimum of (5) switches, both new and used, and they all have this. The one on our shop car is leaking a very minor small amount, and I've never seen one do this before. I have also diagnosed that the car needs a new accumulator as well.
Thanks,
K.
Thanks,
K.
