I recently had to replace the powermaster motor and relay. Voltage was available at pins B and C of the plug going into the relay. I replaced the motor and relay with a known good assembly and everything works fine.
Is there a way to bench test the old motor and relay that I removed to figure out just which part is bad?
I would like to salvage whichever part is good for future use.
