I took my chance to make it work.
First, I am located in Europe (I think it is important info related to the costs mentioned below and shipping issues)
1. Orings for the pump - I got a set of EPDM Orings from UK: https://www.polymax.co.uk/o-rings/rubber-epdm-oring/ (it is extremely important the Oring material vs brake fluid you will choose !!! For DOT3 & DOT4 fluid brake, EPDM as a material for the Orings is OK. Google for it for your safety).
Please note, there are few other EPDM seal components inside the pump and they are not the subject here (I was not able to locate the supply source, however they were looking OK in my pump). One Oring cost about 0,20 -0,30 USD (you need total of 14 Orings, including pressure switch and original accu bowl).
2. Since my accu bowl was dead, I had to replace it, but around $200 at some of US suppliers was looking pricey to me .... After checking here and there, I got a new bowl that was used in BMW and Audi brake systems. Manufacturer is either FEBI or SWAG. I was able to get it for around $55. The bowl capacity is bigger, but actually I think it is OK, as it should make power pump to run less frequently (less start/stop cycles while one cycle will be longer)
3. Since the thread size of the accu bowl is different, I had to manufacture an adapter. It cost me 8 USD.
We will see the results. I will keep you informed, as the system is not installed yet. And I expect few months time while I will be able to test it (currently I am working with suspension and other components / issues of the car ....)
Hope all is understandable, as English is not my native language ....
