Brake pedal went almost to the floor the other day! Had just enough to stop! With the key off and pump them up 10 or 12 times, they will build up but then fall back to the floorboard. BTW, the first couple of pumps you can hear a loud..... Whoosh! Turn the key on and the motor runs for about 15 seconds and shuts off. Press pedal and down they go again! Motor comes on for about 5 seconds and shuts off. I can't see any brake fluid leaking anywhere. The passenger side of the master cylinder looks to have lots of air in the brake fluid, really frothy looking. Is this a bad master cylinder or what?
