f117v6
- Oct 22, 2006
I have been having trouble with my powermaster brake system instantly blows the 30 amp fuse when I turn the ignition on. I'm pretty sure that the motor is shot I have went through the troubleshooting tree and read up on the diagnostic for testing the ports on the motor and the pressure switch. I was doing some other work on the car while waiting for parts to arrive to fix the powermaster and I noticed now that my fan for the radiator does not seem to work correctly are these two linked together through a relay ? or are they two separate relays for wiring diagrams I've read a lot of forums and can't seem to find anything that is definitive if they are separated or not... It brings up another thought to me that I am going to hydroboost system do I need to plug anything into these connections at powermaster if they are connected together so it bypasses the powermaster
