1986_GNAT
- Jul 29, 2015
Hello everybody, I need help finding out if my turbo is going bad and if so, are parts available to rebuild it? The reason I'm asking is because a few minutes after I start the car I get some blue smoke out of the exhaust. once I start driving it and hit a little boost the blue smoke subsides. I limit myself on the work I do on this car because I know this car requires special people with knowledge and experience and that's why I'm here. The cars mods as told to me by previous owner are as followed:
Gn1 Aluminum heads (unported)
55lb injectors
tony de quick inter cooler (smallest of the 2 versions)
Scan master
Modified Ecm to accept different impedance resistors?
3500 Stall
Smc alky (non working controller)
Aftermarket down pipe possible terry Houston
3" K&n cold air intake
I bought some 95lb injectors from somebody on this board that I would like to install. I also want to purchase a new chip from Eric, and Razors alky system but I need to figure out This turbo thing first.
55lb injectors
Scan master
3500 Stall
