Press?
Sleeper
Just curious...
Do you think a 12 ton press will have enough force to remove wheel and axle bearings? The reason I ask, is there is one on sale locally (Princess auto) for a little over $100 and am thinking on picking one up.
Thanks,
Paul
12 ton is more than enough.I cut old bearings off with cut off tool and then press new bearings on.Be careful not to cut into carrier or axles.I cut half way through and use chisel to crack race. good luck
Thanks chopped39 That's what I have been doing. I just thought it would be nicer to use a press.
