turbojimmy
Supporting Member
- May 26, 2001
Hi all,
I’m having a problem with my car that is causing shifting problems. I’m reluctant to say I’m having trouble with the transmission itself because I’ve had two different, freshly rebuilt transmissions in the car and they both behave the same way.
I think it’s a pressure problem. Adjusting the TV cable has no affect on the problem. Here’s what it does:
Under ‘normal’ acceleration, it will shift 1, 2, 3 and 4 without any problem. 1-2 is hard, 2-3 is a little softer and the shift to 4 is barely perceptible. Shift points (RPMs) seem okay. TC locks up very firmly.
Under moderate acceleration, however, the 2-3 gets really sloppy. The harder the acceleration, the worse it is. I can feel it drop out of 2nd at which point acceleration slows dramatically as RPMs increase. At moderate throttle it will eventually (after about a full 1-2 second delay) shift to 3rd and sort of stay there. It will drop out of third if I give it enough throttle but never quite go back down to 2nd – it just slips.
Under WOT the car shoots right to redline when it tries to shift to 3rd. If I let up on the throttle it will shift.
When driving along, when I feel it drop out of 2nd getting ready to go to 3rd, if I give it some throttle I can make it ‘stick’ in between 2 and 3. It doesn’t drop back to 2 nor does it go up to 3.
This is the 2nd transmission from the rebuilder that does this so I’m 99.9999% sure that it’s not the transmission itself. I have had transmissions from him that work great and I have 100% confidence in the rebuilder. So, I don’t want to bring the car back to him unless I’ve exhausted all possibilities external to the trans itself.
Assuming the above sounds like a pressure problem and it’s being caused by an external problem, what are the possibilities? I bypassed the cooler in the radiator, leaving only my external cooler in place, and it does the same thing. Could there be a line pinched somewhere? Could it be the torque converter (I just had Precision go through it a few months ago and it checked out fine)?
Any other ideas?
TIA,
Jim
Any other ideas?
TIA,
Jim
