Okay guys let`s set a few things straight (no pun intended) here. Swaybars are NOT intended to locate the rear axle laterally. Ever. No matter if they`re stock ProTouring or drag race. That`s the job of the upper trailing arms in a C4L suspension such as that of the G body.
What happened here is that the UCAs came loose and the rear end shifted. The swaybar has nothing to do with it. It`s mounted in the same format that almost every single car made with a swaybar has been made with, frame/axle mounted with end links. The factory G (and A) body cars are the oddballs. If you don`t want this to happen simply use a few drops of Loctite on any threaded components you don`t want to have come loose. That`s why they make it.
The watts link we developed for these cars will certainly prevent unwanted lateral axle movement, as well as properly locating the rear roll center. We`re really pleased with how it makes these cars so linear and predictable to drive. If you want one for those reasons fantastic, you`ll be very impressed with it but to say it`s necessary simply because you`re removed the factory LCA mounted rear swaybar and replaced it with a link mounted one is absurd. Mark SC&C
PS. Binding is NOT good.
