Problem at the track!
I did compression test on 2,4,and 6. #2 cylinder is 150 and # 4 and #6 are 120 I had to go to work I will do the other side today. What should the compression be.
do compression test on a warm engine
yank all plugs , pull fuel pump inj fuse , disconnect coilpack , prop throttle body open , make sure battery is good or keep connected to battery booster
crank over about 5-6 cycles for each cylinder
you should read 150psi or so and none should be more than 10% off (15psi variation overall)
