turbobitt
- Feb 14, 2002
I am struggling with a really bad Tip-in throttle response problem. If I just crack the throttle , I get a bad lean condition. If I quickly stab the throttle , Everything works OK. I have maxed out AE vs. TPS and AE vs. MAP and no improvment on slow tip-in. I also played with MAP AE noise limits with no change. I did a search through this forum and found other people with the same problem but no cut n' dry solution. Any ideas ???
Allan Gorneault
Allan Gorneault
